1.464 visninger
evinrude e-tec 90 HK vil ikke vinter komprimering {{forumTopicSubject}}
hejsa er der nogle af jer der har e-tec motorer som har haft problemer nå i skal vinter komprimering ?
Går ud fra at du mener vinterkonservering.
kan du ikke beskrive i detaljer, hvilke problemer du har?
jun 2011
Følger: 1 Følgere: 10 Emner: 10 Svar: 27
jeg kan slet ikke få mine lys tændt første gang
det har aldrig været et problem før jeg har 2 af de motore
apr 2013
Følger: 7 Følgere: 2 Både: 1 Emner: 7 Svar: 63
apr 2013
jun 2011
apr 2013
han løste problemet, med at justere på gaskablet... da den var i neutral var den ikke helt tilbage til stop. Håber du finder problemet.
Vh Jóhann eli
I had a similar problem with a brand new 65hp e-tec. I was advised by my dealer to try this;
Make sure that idle stop of the throttle lever is against the crankcase. Adjust the throttle cable trunnion to align with the trunnion block. Place the cable trunnion in the trunnion block.
IMPORTANT: Move control handle to FORWARD
and pull back slowly to NEUTRAL. Make
sure the engine throttle lever is against the stop. If
not, remove slack by adjusting cable trunnion.
Install the trunnion cover and screw. Tighten the
retaining screw to a torque of 60 to 80 in. lbs.
I did this and it worked! Pls. let us know how it all turned out. Good luck
jun 2011
Følger: 61 Følgere: 100 Både: 5 Emner: 14 Svar: 1.429
